Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-22-2013, 09:16 AM
drew300 drew300 is offline
steering fault
My '99 SW1 has developed a steering problem. There is a hard spot just each side of center. It's at a stage where i don't feel it all the time, but it is there. I've changed the power steering fluid twice, and it's clear, I've lubed the universal joints in the steering column. When jacked up or on the ground I can't feel any looseness in any front end part. I'm guessing it's the rack, but other suggestions would be welcome.
Old 05-30-2013, 03:32 PM
jamesslcx jamesslcx is offline
Re: steering fault
Drew, it's possible it could be the rack and pinion. Any noise or other symptoms?
Old 06-03-2013, 07:34 AM
Re: steering fault
I may have found something. I sprayed all the U-joints in the steering column with penetrating oil. after about a week the steering seems better, but i'm paying attention for a while yet. I have yet to spray a better oil or grease on them.
Old 06-03-2013, 01:09 PM
Re: steering fault
Drew you may have found your problem. Let us know how it works out.
Old 06-25-2013, 01:01 PM
Re: steering fault
I'm sure it was the u-joints in the steering column. The fault went away several days after i oiled them. I have since sprayed some grease on them. I don't know which one it was, as I sprayed them all while I was there. I'm happy it was a cheap fix.
The Following User Says Thank You to drew300 For This Useful Post:
jamesslcx (06-25-2013)
Old 06-25-2013, 01:07 PM
Re: steering fault
Thanks for the tip, good to know there is a cheap fix.
