Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-18-2013, 09:18 PM
rontomed's Avatar
rontomed rontomed is offline
Question Erratic Power Door Locks
I have a 1999 Dodge Ram 1500 5.2L V8 extended cab. I locked my keys in the other day and called AAA who arrived promptly. He placed two wooden wedges between the glass and lower outside window seal on the passenger side door. Using a probe with a hook on the end his first pull missed it's intended mark but the second opened the passenger door. I've sense noticed that most attempts to lock or unlock the truck do not work for the driver side but always works for the passenger side. This is true with either the remote and each inside power door lock switch.
Is it possible that I need to retrain the power door locks or maybe he damaged something with the probe on the passenger side that affects the driver side?
Old 05-18-2013, 10:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Erratic Power Door Locks
Sometimes I have to hit the button more than once to get action.
I'm gonna blame mine on well used contacts and occasional rain from the window being cracked open.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
