Old 05-14-2013, 10:12 PM
richkuan richkuan is offline
92 Accord ABS Problem
Pros,
The ABS is acting up sometimes. It activates when I am not braking, or it resets itself from time to time, or I can hear it making some noise (d d d d d d d d ....) from time to time. And the brake light doesn't come up.
Anyone knows what's wrong and how to fix it? Thanks.
Old 05-15-2013, 07:29 AM
65comet's Avatar
65comet 65comet is offline
Re: 92 Accord ABS Problem
I haven't had to touch the brakes on the 93 Accord I picked up last fall, so I'm not exactly sure that they work the same as others I've worked on. But here are some things to check based on my experience with other cars. A square toothed ring rotates with the axle. A magnetic sensor reads the teeth to tell the rotation speed. The ring can crack and open up, creating a larger gap between teeth that confuses the sensor. A tooth can also be broken off. The sensor, because it is magnetized, can get a buildup of metal dust and shavings on it, causing it to not read correctly. These are the simple things from a visual inspection. Most other problems need to be diagnosed with a brake scan tool.
Old 06-07-2013, 01:16 PM
ProMan ProMan is offline
Does the brake warning light ON? Can you read any error code?
The Following User Says Thank You to ProMan For This Useful Post:
richkuan (07-31-2013)
Old 07-31-2013, 12:09 PM
Sorry for the late reply. I just would like to update the status.
Problem solved!!
Yes, the ABS light came on from time to time, when it's on, the random reset and activation was gone. I believe the ABS got disabled.
I checked the code, it's 44, RR ABS sensor. I cleaned the teeth and sensor head. The teeth are clean, the head had some debris, but no good. Then I went ahead checked the wiring. When I unplugged connector, I noticed the sensor side is kind of rusted. So I use sand paper to polish the 2 leads, and ABS is back to normal!!
Thanks for your help.
