Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 05-14-2013, 02:05 PM
groovyforster groovyforster is offline
2003 Toyota Corolla Timing Chain Tensioner Replacement
I have a 2003 Toyota Corolla with a leaking timing chain tensioner. I was able to locate a procedure for replacing the tensioner but it didn't say whether the no. 1 cylinder had to be @ TDC or not. What is the proper procedure for this repair?
Old 05-20-2013, 11:24 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2003 Toyota Corolla Timing Chain Tensioner Replacement
If you remove the timing chain for some reason, it is best to have the crank at TDC for No. 1 cylinder so that all the timing marks line up. If you have not removed the chain, then there is no reason to have the crank at any particular point in the rotation. Just make sure the chain doesn't change position on the cam gears or the crank gear while it has no tension.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
