Old 05-12-2013, 11:10 PM
DavidScott2580 DavidScott2580 is offline
Exclamation 01 Blazer Dies When Given Gas
I Am working on a 01 blazer that will start and idle but when given gas it will die sometimes i can get it to rev up but most of the times it dies if put into gear and try to go it dies. things that have been changed fuel pump, maf, wires, plugs, cap, rotter,fuel filter, it wont pull any codes except a fule level censor high voltage wich is why the gas gage keeps jumping but i couldnt think that would stop it from running
Old 05-24-2013, 09:07 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 01 Blazer Dies When Given Gas
Check the EGR and IAC valves as well as the vacuum lines. Also test the fuel pressure.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-02-2013, 06:56 PM
ASE AMD ASE AMD is offline
Sounds like fuel pressure.
Old 09-01-2013, 08:33 PM
blazerchaser blazerchaser is offline
Try checking the fuel filter also if its dirty enough it won't be getting enough gas and will die when you try and push the pedal.
