Old 05-11-2013, 07:48 PM
kingjames1 kingjames1 is offline
2003 Trailblazer ignition key issue
This past winter my daughter was coming home when her Trailblazer would not shift gears. When she got home she parked it and used her other car for the rest of the winter. Then this spring she pulled the Trailblazer outside and parked it. A couple weeks later she went out to move it and the key would not turn.
I put a new battery in but still can't get the key to turn. It seems to be locked in the OFF position. Is there a trick to get it to move again? Thanks.
Old 05-12-2013, 07:21 AM
Tech II Tech II is offline
Re: 2003 Trailblazer ignition key issue
Try rotating the steering wheel left and right as you turn the key.....
Old 05-12-2013, 08:04 AM
That didn't work. I tried moving the gear shifter also, but nothing.
Old 05-12-2013, 10:44 AM
Key should turn with the battery disconnected.....bad key? Have another to try?
Old 05-12-2013, 05:52 PM
I'll give that a go. I'll get back either way. Thanks.
Old 05-27-2013, 06:00 PM
Now that's strange. My key used to work and now I can't even get it to go in all the way. Both keys are identical. Needs a new ignition switch?
Old 05-28-2013, 09:48 AM
Schurkey Schurkey is offline
Sounds like the lock cylinder is broken.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-28-2013, 10:06 AM
I agree....if you can't even get the key in.....it's something to do with the cylinder......remember, the lock cylinder is not your ignition switch.....though a lot of people confuse them....
Old 05-28-2013, 01:25 PM
aleekat aleekat is offline
I would spray some lube in it first.
Old 05-28-2013, 04:37 PM
alright I'll give that a go.
Old 05-29-2013, 02:54 AM
I thought lock cylinders were a common problem on Trailblazers and Envoys.
Seems I read a thread about them not taking kindly to a heavy ring of keys.
