Old 05-07-2013, 01:47 PM
morgan1979 morgan1979 is offline
01 windstar 3.8 catalytic converter stopped
Only one of the convertors are stopped the other two are fine. This one is glows red. Being that right now is a hard time financially for our large family whats the best fix? The part store seems to only sell the whole unit which is almost 500 dollars. The van currently is sitting due to how bad it is driving. by the way i live in Alabama there is no emission law. Im just needing something to get me by 3-4 weeks.
Old 05-07-2013, 10:06 PM
kevink1955 kevink1955 is offline
Re: 01 windstar 3.8 catalytic converter stopped
If it's glowing red it is most likely working and burning off excess fuel from a poorly runing engine. Find out what is causing the rough runing and the convertor will go back to normal
The Following User Says Thank You to kevink1955 For This Useful Post:
morgan1979 (05-08-2013)
Old 05-07-2013, 10:30 PM
Windstartled Windstartled is offline
Check codes for a misfiring cylinder and/or visually check plugs, plug cables and coil pack. Like Kevin says you're likely leaking fuel into the cat and the most common cause of this is a cylinder with a no-spark condition. This causes the fuel delivered to that cylinder by the injector to be wasted and travel down the exhaust system into the cats where it just burns. Also a misfiring cylinder will cause the engine to run very rough at idle as if it had a major vacuum leak, but with more vibrations. As far as troubleshooting is concerned a cylinder with a no-spark condition is pretty easy procedure. Sings of a single-cylinder with no-spark condtion are very rough idle, lack of power, fuel smell or dripping from tail-pipe jerky acceleration that could be mistaken for tranny issues, poor fuel economy, cussing driver.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
The Following User Says Thank You to Windstartled For This Useful Post:
Old 05-08-2013, 01:47 AM
We been getting a constant code of bank 1 to lean . New spark plugs but had to drive a few miles with a misfire from bad spark plug to get it home the other day. Will most definitely check into to seeing of anything is wrong with the new plugs.
Old 05-08-2013, 02:27 AM
If the problem appeared or got worse after the new plugs were installed check if proper plugs were installed and properly seated, check all plug cables and connectors then if that does nothing remove the coil pack and inspect it for cracks with a magnifier under a bright light. Haynes manual would be very handy if you don't already have it. It can save you thousands in repairs and diagnosis procedures.
Old 05-08-2013, 03:41 PM
Thanks I discovered cylinder 5 is the problem. When i get off work im going to check the plug and the coil. I had just enough time this morning to unplug wire by wire and sure enough it was #5.
Old 05-08-2013, 08:15 PM
Ok one and five are not firing. There is no fire from the coil itself on these two. Wire and plug is good. Advice? New coil?
Old 05-09-2013, 07:07 AM
northern piper's Avatar
northern piper northern piper is offline
i'd be replacing the coil for sure. 1 and 5 are connected.The pattern of connection is:
Cylinder numbering:
  • Windshield side
    1--2--3
    4--5--6
    Frt. Of vehicle
Coil numbering:
    • --4 PIN--
      --1--- 2--- 3--
      --5--- 6--- 4--
  • NOTE the irregular sequence on the 5-6-4 side. Weird, but that's the way it is.
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 05-09-2013, 01:16 PM
Cylinder numbering:
  • Windshield side
    1--2--3
    4--5--6
    Frt. Of vehicle
Coil numbering:
    • --4 PIN--
      --1--- 2--- 3--
      --5--- 6--- 4--
Thanks replaced it last night and now head gasket done. This van sure turning into a headache.
