Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-07-2013, 11:22 AM
Panoz60's Avatar
Panoz60 Panoz60 is offline
Diff Cooler mount
So, I just spent an hour laying under the back of my car with my newly aquired differential cooler and I still cannot find a logical place to mount it. Taking into account the need for air-flow and protection from debris, etc, I'm all over the place. I'm thinking inside the trunk area with a fan?
Since GTS models came with one, can somebody please give me some direction? Pics would be awesome too.
Thanks in advance
Mark W.
Panoz GTRA, Chassis #10
Old 05-07-2013, 12:43 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Diff Cooler mount
GTS models had a screened scoop that extended below the car.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
The Following User Says Thank You to Cobra4B For This Useful Post:
Panoz60 (05-07-2013)
Old 05-07-2013, 01:02 PM
Panoz60's Avatar
Perfect. Thanks.
Mark W.
Old 05-08-2013, 01:35 PM
Don O.'s Avatar
Don O. Don O. is offline
Hey that's my cars pictures! Kidding glad to share. I did mount a tranny cooler behind the fuel cell with an electric fan and it works great!
Don
Old 05-08-2013, 01:39 PM
Don O.'s Avatar
BTW that cooler scoop does not look as nice as that anymore. A few wide trips over the rumble strips tends to flatten it out a bit but it still works!
Don
Old 05-10-2013, 05:37 PM
NZGTRA17 NZGTRA17 is offline
Thanks in advance
Mark, I am just finishing off mounting diff and trans coolers. I have used a similar location as the GTS cars. I did this to prevent damage to any air scoop mounted below the car as at present I have regular off track excursions.......
I have mounted both coolers in line, on the RH side of the car up high above the diff. I have built a "pressure box" above the coolers that I am feeding cooling air into via a NACA duct in the top of the RH rear guard (will probably put a semi scoop at the back of the duct to boost duct performance). The hose for the duct mounts into the side of the top of the RH wheel well.
Will post some pics when finished but this configuration has some different ideas to the factory options I have seen so far.
Kel.
Kel M
Panoz GTRA #17
New Zealand
The Following User Says Thank You to NZGTRA17 For This Useful Post:
PanozDuke (05-16-2013)
