Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-03-2013, 01:17 PM
dclegg61 dclegg61 is offline
98 rodeo - engine speed drops to idle while driving
have a 98 rodeo, with a V6 & Auto trans. have an intermittent problem - as I am driving engine will occasionally drop to idle speed and then pick back up to driving speed. Engine keeps running smoothly, just at idle speed.
CEL does not come on / no codes
Replaced Throttle Position Sensor - and thought I had found the problem, but since it is so random, it just didn't happen again for 1 1/2 weeks.
Anyone else have this issue?
Suggestions?
Old 05-03-2013, 10:22 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 98 rodeo - engine speed drops to idle while driving
very odd since the throttle is just an old cable style ...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-04-2013, 04:17 PM
"very odd since the throttle is just an old cable style ..."
That is what I thought, Amigo-2k. That is why I thought maybe the TPS was not reading the open throttle and not telling the computer to give it more gas. But, apparently I was wrong. lol
Old 05-12-2013, 09:21 PM
Update
I cleaned the Mass Air Flow sensor & replaced the fuel filter.
Still no solution....
Old 05-15-2013, 10:55 AM
WhiteRodeo4x4's Avatar
WhiteRodeo4x4 WhiteRodeo4x4 is offline
clogged converters??
Old 05-15-2013, 03:06 PM
Ooooo.... that doesn't sound good. Is there a way to tell for sure without replacing them? Do any of the Catalytic Converter cleaners really work?
ALSO, I checked the fuel pressure at the fuel rail. 50psi with vacuum hose disconnected from fuel pressure regulator. 37psi with vacuum hose connected. Pressure regulator was replaced just over a year ago.
Old 05-15-2013, 04:55 PM
I actually took mine to Mineke Muffler and they checked it for free. The can check the back pressure. Mine had a left clogged converter and it would slow down to 40 mph on a hill. You could also hear a louder noise coming from the air box (air filter housing) when giving it the gas.
Old 05-16-2013, 08:15 AM
Thanks, I'll give that a check.
Tags
idle , rodeo
