Old 05-01-2013, 03:26 PM
Wim Warnez Wim Warnez is offline
Turbo's
Hello everyone,
Why do car manufacturers use multiple turbos on one engine?
regards
Old 05-01-2013, 07:32 PM
maxwedge maxwedge is offline
A990 racer
Re: Turbo's
Usually to eliminate turbo spool up lag.
Old 05-01-2013, 11:45 PM
vgames33 vgames33 is offline
Re: Turbo's
Two small units can spool up faster than a single, larger unit. Faster spool results in better engine response.
The other option is to use a small turbo and a large turbo. This is called a "sequential" setup. The small turbo provides instant power and the larger unit takes over at higher RPM.
A single turbo setup is generally cheaper and more reliable.
Old 05-02-2013, 12:55 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Turbo's
And if the engine is a v-style engine, it's common to install one turbo on each banks' exhaust manifold. The described sequential setup is more common on an inline engine with a single bank of cylinders.
-Rod
