Old 05-01-2013, 03:17 PM
Wim Warnez Wim Warnez is offline
Compression ratio
Hello everyone, I have a question about the compression of an engine.
For what use do people change the compression ratio of their engine?
Regards,
Wim
Old 05-01-2013, 07:31 PM
maxwedge maxwedge is online now
A990 racer
Re: Compression ratio
Higher compression to a point results in more power.
Old 05-01-2013, 11:40 PM
vgames33 vgames33 is offline
Increased compression provides more power, especially at lower RPM. Too much compression can cause the fuel to ignite too early and will cause damage.
Some people lower their compression ratio to allow their engine to run with more boost pressure from a turbo or supercharger.
Old 05-02-2013, 11:35 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Higher compression improves the thermodynamic efficiency of an engine, that is, it allows the engine to convert more of the fuel's chemical energy to force (power) instead of heat. This improves both power and fuel economy.
