Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-28-2013, 06:46 PM
mtc111009 mtc111009 is offline
88 GMC C2500 Brake problems
Hi have a 1988 gmc c2500 with brake problems. the front brakes keep locking up both sides. Have replaced the calipers rotors pads and the brake lines. I can bleed them off and they release but has soon has you it the brakes they loock up again. Im at wits end any help would be great thanks.
Old 04-29-2013, 08:50 AM
maxwedge maxwedge is offline
A990 racer
Re: 88 GMC C2500 Brake problems
Brake hoses were replaced, no? Any work done on the master or booster, then this happened? Do you have Hydro-Boost.
Old 04-30-2013, 06:35 PM
Yes lines were replaced nothing done to the master or booster
Old 04-30-2013, 06:36 PM
no hydro boost
Old 05-01-2013, 12:24 PM
A990 racer
Ok, when the brakes lock up, disconnect the vacuum hose to the booster see if they free up.
Old 05-02-2013, 08:14 AM
Hi tried the line going to the booster they still stay lock up after taking off the air line
Old 05-02-2013, 08:38 AM
A990 racer
Are you sure the hoses were replaced you keep saying lines? Also make sure there is at least 1/8-1/4 free travel in the brake pedal.
Old 05-05-2013, 10:20 PM
yes hoses were replaced and i have 1/8 to 1/4 travel in the pedal.
Old 05-06-2013, 07:50 AM
A990 racer
Possible the proportioning valve is bad and holding pressure, not much else left.
