Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-27-2013, 12:18 PM
David Eastman David Eastman is offline
Rotors
Its time for new rotors and was wondering what other people are using sense PFs are no longer available.
David
Old 04-28-2013, 07:47 AM
panozracing's Avatar
panozracing panozracing is offline
Re: Rotors
I have only used Brembo. From what PAD told me they are about the same price. Works well.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 04-28-2013, 02:40 PM
Panoz60's Avatar
Panoz60 Panoz60 is offline
Re: Rotors
Lots of choices there...
Coleman, AP Racing, AFCO, Allstar, Wilwood, Brembo. I'd shop around for prices. Here's a good site to compare prices... http://pitstopusa.com/c-131761-brake...ke-rotors.html
I've run high-dollar rotors before and honestly noticed no difference from less expensive ones. They all seemed to wear about the same. Then again, I wasn't running races longer than 40 minutes. I did learn that properly bedding them will make them last a lot longer.
I would suggest any of the manufacturers I mentioned above, but stay with 48 or more vanes. I think vane counts under 48 are too light for cars above 2800# or so.
My opinion, and like my wife says; I always have one
Mark W.
Panoz GTRA, Chassis #10
The Following User Says Thank You to Panoz60 For This Useful Post:
PanozDuke (05-16-2013)
Old 04-30-2013, 06:45 AM
glenbinegar glenbinegar is offline
Re: Rotors
Hi David, I just had a pair of front rotors made at Coleman. With balancing and shipping came to about $250 each. The mounting bosses were incorrectly machined, but they paid the return shipping and corrected the problem at no charge. It did add about 3 weeks of down time though. Are you going to Sebring this weekend? Glen
G;-)
Old 04-30-2013, 07:05 AM
Re: Rotors
Thanks for the help guys.
Glen did Coleman assign a part number to the rotors for future orders and what hardware are you using? No not going to Sebring I am heading to RA.
Old 04-30-2013, 01:06 PM
Wess-RA's Avatar
Wess-RA Wess-RA is offline
Re: Rotors
I have a new set of brand new PFC rear roters to sell. See my previous posting labeled "rear bumber and rear rotors" down below.
Thanks.
Uwe W.
Panoz GTS
Porsche 996 Turbo
Old 05-03-2013, 05:42 PM
boothkc boothkc is offline
Re: Rotors
The "school cars" (GTRA etc) used Performance Friction rotors. The GTS cars use Brembo rotors. The early GTS Brembo rotors are no longer made and require using a new same size that fits the new hats (center part).
Not sure what you have but hope the history helps.
Kevin
Old 06-24-2013, 07:28 AM
Re: Rotors
Hi David, Have you got your new rotors? I am pleased with the rotors I got from Coleman. Are you going to VIR with Chin? I am replacing the upper A-Arm monoball bearings now and expect to be ready for VIR. Glen
G;-)
Old 07-01-2013, 07:47 PM
Re: Rotors
Glen good to see you are getting the car out again. I got new rotors from Coleman last week but I have not had time to install them yet. No not going to VIR but I will be at RA the end of July and August.
David
Old 07-06-2013, 12:30 PM
Re: Rotors
Hi Dave, just back from VIR and prepping the car for Barber next weekend. I will be at RA 8-24 & 25. Looking forward to seeing you there. Glen
G;-)
Old 09-23-2013, 09:32 AM
COBRA77 COBRA77 is offline
Re: Rotors
How did the Coleman rotors work out for you?
Old 09-23-2013, 01:47 PM
Re: Rotors
The Coleman rotors are working as good as the last rotors, have been to: Barber, VIR, Road Atlanta, CMP and Sebring. They use the same old style fasteners as the original rotors. If I do it again I will change the mounting hardware (type) as I used up my new spares for that installation. G;-)
G;-)
Old 09-23-2013, 08:37 PM
Re: Rotors
Thanks for the quick reply! Good to hear they are doing well compared to the PF's. I understand the Coleman rotors have 30 or 32 vanes. Are the vanes thicker or are the air gaps larger (or both)?
Pricing for floating rotors as of this morning are ~$207 for ones comparable to the PF's on GTRA's...
