Old 04-25-2013, 06:38 PM
mustang_guy3 mustang_guy3 is offline
200 Chevy S10 Blazer A/C Problem
Okay I am having a problem with my A/C in my Blazer I've had my compressor replaced finally got all of my leaks fixed and replaced all the visible vaccum hoses and still without by passing my heater core I have no Air Conditioning. It just keeps blowing out hot air. No one seems to know or have any idea as to why my Air Conditioner is working. I really like my blazer but after having invested a little over 600.00 into just getting the A/C up and going with no luck is just getting frustrating. I am considering selling it and getting a truck. I would like to keep it if I can get the A/C up and going but I don't want to have to invest a whole lot more money into it. If anyone can help it would be much appreciated.
Old 04-25-2013, 08:20 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 200 Chevy S10 Blazer A/C Problem
Do you have manual system? or climate control? Sounds like your temp door is dangling loose- or a bad temp door actuator. You can pull off actuator- it's tight but do-able. It is on top of HVAC case- open glove box and drop it down- then work to get the screws out of temp door actuator- once it is out, you can see if it reacts to control head temp commands- and you can also move temp door with your fingers to full cold and full hot- and see it your system works then.
I suspect you have a broken drive gear internal to the actuator- which requires a new actuator- if it does not move in above test- there-in is your problem.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Tags
a/c , blazer , heat
