Old 06-07-2003, 11:09 PM
raptornt raptornt is offline
Question Civic won't start
My 94 Civic EX had been running fine.Today I decided to change the plugs and wires.Car ran fine for about 3 hours.I was on the way to a friends house and the car just stalled.Motor spins but will not crank.Pulled spark plugs out and no spark.Checked rotary button and it is turning.First guess is the ignition coil.Is this something I can replace myself?Any other suggestions?Please Help!
Old 06-07-2003, 11:24 PM
BullShifter's Avatar
If the motor is turning over its cranking. You have a crank/no start problem. No crank is nothing at all.
Replacing the ignition coil is simple.
1. Disconnect negative battery wire
2. Remove distributor cap & cap seal, then remove leak cover
3. Disconnect 2 wires from coil
4. Remove 4 screws from the coil
Old 05-03-2004, 07:14 PM
BoOst@2BaRz BoOst@2BaRz is offline
Send a message via Yahoo to BoOst@2BaRz
Talking
my 94 civic ex has the same prob.i think its the coil,but,i am getting a ohm reading from it from 2 plugs to the spring.But some1 said it be the ICM(ignition control module).could be those two.damn i need help too let me no how it goes
