Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-19-2013, 01:56 PM
khwrbmlfe2013 khwrbmlfe2013 is offline
06 Silverado Tranfer case
I have replaced my trans and now I have a problem with it going into fall safe mode. I was told it was to do with a sensor on the transfer case. Could this be my problem? I can turn the truck off and turn it back on and it will shift out, but when I stop and start to take off it goes back into the fall safe mode, staying in high gear.
Old 04-19-2013, 06:52 PM
j cAT j cAT is offline
Re: 06 Silverado Tranfer case
what is the vehicle doing wrong ? never heard of fall safe mode before.
what are the error codes ? drive train failure codes with a reader that reads these ?
The Following User Says Thank You to j cAT For This Useful Post:
khwrbmlfe2013 (04-19-2013)
Old 04-19-2013, 07:33 PM
Thanks for the reply. I crank up shift into drive and it pulls off and shifts thru the gears when you stop and pull off it seems to be in high and will not shift. I then turn the truck off and start it back up and it then shifts thru the gears until I stop.
I have not had it put on a computer so I dont have any codes. Have been told it has to do with electronics at the transfer case.
Old 04-21-2013, 05:19 PM
IN THE TRANSMISSION are two solenoids. these after 180,ooo miles need replacing especially if you did not replace the fluid/filter on a regular basis and use the now GM dexron VI approved transmission fluid for your vehicle. dexron III is no longer the GM approved fluid.
anyway when these get eaten by the acidic fluid they can stick. sometimes you will loose 3rd or 4th gear when worn bad enough ..
Old 04-23-2013, 07:27 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
khwrbmlfe2013,
I see that jcAT is assisting you in regards to your transfer case situation. I would like you to know that we are also here to assist you. Thank you.
Erica Tiffany
Chevrolet Customer Service
