Old 04-18-2013, 12:37 PM
Electric_mouse Electric_mouse is offline
Code 13 1990 PA, 3800 engine
Have been getting a lot of code 13 Oxygen sensor. I cleaned the orig, minor improvement, replaced with a used one with slightly better preformance but it still triggers a service engine light after about 100 kmph. Hey I should be happy. It's getting better. Most often it will cancel the light when slowing down and don't often see this in city driving. Guess it's off to the wreckers and grab a handfull of the darn things.
Is this a common problem?
TIA
Old 04-18-2013, 05:57 PM
Tech II Tech II is offline
Re: Code 13 1990 PA, 3800 engine
If you had a scan tool, you could easily test the circuit to the ECM......
Common problem? Not really.....it's a 23 year old engine......by now, should have had at least two put in.......can be contaminated by a coolant leak, or a lean condition which would cause the engine to run rich and carbon up the sensor....
Putting in used O2 sensors is hit or miss.....
Old 04-19-2013, 08:57 AM
maxwedge maxwedge is offline
A990 racer
Single wire 02 about 23.00!!
Old 04-20-2013, 01:01 PM
Blue Bowtie's Avatar
Registered Offender
With the OČ disconnected, KOEO, check for a 450mV bias signal from the ECM at the OČ connector.
Old 04-20-2013, 07:14 PM
My wrecker buddy suggested I try another EGR. Took it for a drive and the code never came up. (yet)
Measured the voltage as you suggested. I get 195 mv.
Old 04-25-2013, 05:43 AM
Follow up on the bias signal. I obtained a second ECM and again measured the voltage. With this box I get just short of 400 mv. How important is the bias signal voltage? I notice no difference in performance but haven't really tested fully yet. Will be hitting the highway tomorrow for a 1000 mile journey so should be able to get a fairly accurate mpg reading. I know my mileage recently certainly has deteriorated.
Old 04-30-2013, 11:50 AM
Update:
Have returned and results are much much better. My mileage this trip averaged just over 30 mpg. That's an improvement of about 5 mpg over the same trip in February. On previous trip the code 13 was on almost continuous. This trip not once! Both oxygen sensors test similar on the bnech but the code still came up. The EGR seemed to to be the culprit for the code 13. Which single item or was it a combination of all 3 items that are responsible for the considerable improvement in gas mileage?
Old 04-30-2013, 01:59 PM
My guess would be your ECM....
The Following User Says Thank You to Tech II For This Useful Post:
Electric_mouse (04-30-2013)
Old 05-03-2013, 07:46 AM
Jrs3800 Jrs3800 is offline
The ECM's in the earlier 3800's had some issues... some did 50k other did 150k..
Glad to see you are getting 30 Mpg.. With the 2.84 gears they can do a bit better than that..
If you buy a new sensor I would recommend looking for an AC Delco AFS-20..
Also if the MAF sensor has never been cleaned it may be due for a cleaning..
When I was driving my 91 Bonneville on the interstate I easily pulled 31 going well over the 70 Mph limit.. Miss that car..
The Following User Says Thank You to Jrs3800 For This Useful Post:
Electric_mouse (05-04-2013)
