Old 04-15-2013, 06:23 AM
slayer5's Avatar
slayer5 slayer5 is offline
valve seats ?
My wifes 2000 chevy metro has smoked on start-up for years. Its just at the point where I need to do something about it. Alot of smoke , but, start-up only. It has 170,000 miles runs good. Is there a link where I can go step by step to complete the job, I don't mind taking the head off if I have to.
Old 04-15-2013, 05:28 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: valve seats ?
probably just need new valve stem seals but takes a special compressor to remove spring and head has to come off, machine shop can tell you if the guides are also bad
Old 04-16-2013, 05:53 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: valve seats ?
I'm guessing it's a four cylinder, the G13BB 16 valve engine is famous for bad valve stem seals. It's possible to replace the seals without removing the head using air pressure or filling up the cylinder with string to hold the valve closed while you take off the springs and replace the seal. At 170K you probably need a valve job and rings though, do a compression and leak down test. You're probably better off going ahead and doing a rebuild.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
