Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 04-13-2013, 02:40 PM
thomas luke thomas luke is offline
454 chevy truck engine into 1979 Camaro
hello I have a 1984 454 out of a motor home I want to install into my 1979 z28 camaro is any problems with oil pan not fitting . I have made some cardboard templates to check the clearance looks like it will fit any comments ?
Old 04-13-2013, 04:40 PM
maxwedge maxwedge is offline
A990 racer
Re: 454 chevy truck engine into 1979 Camaro
Welcome to AF, make sure that is not a high deck truck engine and those engines had very small ports and valves, not really performance oriented.
Old 04-14-2013, 12:04 AM
thanks for the info I have put 781 heads with 2.190 and `1.88 ex. new cam.what I need to know will the stock oil pan fit in the Camaro ?
Old 06-24-2013, 12:14 PM
CORE402's Avatar
CORE402 CORE402 is offline
Are you trying to install the big block on small block motor mounts? If I remember correctly you need to find a set of big block motor mounts in order for things to fit correctly. I tried to install a BBC 402 into my 1973 Camaro years ago and just found it to be too much of a hassle to stick the big block in there. Not to discourage you, in fact I hope you do it. Keep us updated on the build.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
