Old 04-13-2013, 09:26 AM
mayhemrus mayhemrus is offline
85 s10 blazer, overheat
I changed 2 sensors and thermostat. After driving about 3 blocks temp gage led to hot. What now?
Old 04-13-2013, 10:39 AM
jdl jdl is offline
Re: 85 s10 blazer, overheat
How hot is the engine getting in degrees F? If you have a coolant recovery reservoir, is it boiling over?
Old 04-13-2013, 10:48 AM
I havnt checked coolant temp, but reaservor is not boiling. Flush engine maybe?
Old 04-15-2013, 08:17 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
What antifreeze are you using, Green or Orange? What color is your antifreeze now, Brown muddy looking? When was the last time you flushed the cooling system? Are you using A 50/50 MIX? Are you using distilled water with your antifreeze? Have you ever replaced the Radiator? How about the Fan and Shroud, still in good shape?
You might try a good flush and try running straight water as a test and see if that helps. You have no need to worry about freezing in Phoenix now. If this is the original radiator, you probably need a new one.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
