Old 04-12-2013, 10:26 AM
JStin JStin is offline
98 Intrigue shuts off hitting bumps
The shutdown happens a few times a year. Got worse recently after topping off tire pressure. I'm assuming this is a ground issue. Will check the ground coming off the battery if there is one. Any other ideas? Everything else seems fine other than lots of radio static on some days.
1998 Olds GLS Intrigue 3800 Series II - 99,000 mi.
Old 04-15-2013, 01:51 PM
rkvons's Avatar
rkvons rkvons is offline
Re: 98 Intrigue shuts off hitting bumps
I'm assuming this is a V6. Find your ICM and locate the two wire connector on it that goes to your Camshaft Position Sensor. It runs down the back of the engine and, over time, could end up with brittle insulation and touching your exhaust manifold. Make sure the wire is intact and the connections at both ends are good. You can jiggle the wire while the engine is running to see if it stalls on you. Don't pull too hard though. If it is the problem, it is sitting on the edge of failure and if you pull too hard, you might move it away and loose your issue, if you know what I mean.
