Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-10-2013, 08:29 PM
NZGTRA17 NZGTRA17 is offline
Adjusting Front Roll Center
Has anyone tried adjusting and track testing the front roll center on thier cars? I am fitting new upper arms and ball joints.
My front end is currently set up with 1 thick, 1 medium and 1 thin spacer washer under the upper ball joint (the Coleman kit comes with 1 thick, 2 medium and 1 thin spacer).
I am interested in what results people have got from adjusting the roll center and what settings they setttled on.
Thanks, Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 04-15-2013, 09:29 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Adjusting Front Roll Center
Our car had the uppers done backwards. In redoing it I followed the GTS assembly manual directions:
"install lower monoballs into control arms if they are not already installed. There should be 1) 1/2" spacer between the monoball and control arm and 1) 1/8, 1) 1/4, and 1)3/8 spacer below the control arm followed by the nyloc."
and
"Make sure there is 1) 1/4" spacer above upper monoball and 1) 1/8", 1) 1/4", 1) 3/8" spacer below upper monoball."
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
The Following User Says Thank You to Cobra4B For This Useful Post:
NZGTRA17 (04-16-2013)
Old 04-16-2013, 01:38 AM
and
Thanks Brian. I have written to Panoz on this as I am interested in what roll center testing was/has been done and any grip benefits that may have resulted. Will advise if there is any info of benefit.
Kel.
Kel M
Panoz GTRA #17
New Zealand
