Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-10-2013, 06:41 PM
spoiler429 spoiler429 is offline
92 ford ranger starts hard
I have 92 ford ranger 2.3 PFI waste spark system, truck starts hard sometimes it just cranks and then starts or it grunts like the timing is off then another attempt it kick out the starter drive while it cranks. another attempt a revolution and a half it pops right off. it appears the dis module has been replaced new starter, i replaced crank sensor, balancer and plug wires. plugs look like things are a little rich. i double checked the cranksensor voltage which is around 6v but with the DVOM connected it starts normally. Help.
Old 04-15-2013, 01:20 PM
DonSor DonSor is offline
Re: 92 ford ranger starts hard
I don't suppose you noticed any check Engine Light (CEL) indication, did you. It looks like you've tried replacing relevant parts at random. if I were you I would take it to a shop and have them run a diagnostic check. It'll cost you around a hundred bucks but it may save you time and money in the long run to be able to pinpoint your problem.
Old 04-16-2013, 11:22 AM
yes, nothing relavant to the problem as far the codes, this truck has been molested under the hood so it coming down to checking each wire and circut. thanks for the reply
