Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 04-10-2013, 05:55 PM
HeWhoKillz HeWhoKillz is offline
clutch bleeding or something else?
My clutch resevior in my 85 300zx turbo 5 speed ran dry. I filled it up only to see the clutch pedal is still at the floor and doesn't come back up. I was told I just needed to bleed the clutch. I figured it was like bleeding brakes so I went to the pep boys to get a bleeder kit and told them what I was trying to do and my problem but they say I would need to bleed the master cylinder which involves some vacuuming and a bunch of other stuff that they said was "tricky". What do you think is the problem?
Old 04-10-2013, 10:57 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: clutch bleeding or something else?
You need to start by determining why the cylinder went try. If you've got a leak, you need to fix that before bleeding. If you don't have a leak, then you need to replace the clutch.
-Rod
Old 04-11-2013, 08:58 PM
-Rod
If the clutch is bad, I don't see how the resevoir would leak. It is possible, but not a good idea, but the car does not need the clutch pedal depressed when starting. As bad of an idea as it was, when I first had this issue, I started the car in first gear without using the clutch and the car drove around the corner to my house.
Old 04-11-2013, 09:48 PM
shorod's Avatar
SHO No Mo
Since the clutch is hydraulic, it has a piston somewhere that presses on the clutch fork. If there is no leak, that would suggest the piston is extended and the fluid is taking up the slack in the slave cylinder which means something is worn out. This is similar to what happens to cause a low fluid level in a brake master cylinder due to worn pads/shoes.
-Rod
Old 04-12-2013, 04:39 PM
-Rod
Can the car still operate without the clutch?
Old 04-13-2013, 06:38 AM
DeltaP DeltaP is offline
It'll be OK to get it home but I wouldnt be drivin it around esp. in traffic. If you're good you can shift it w/ RPM's but it would be rough on the synchros.
Old 04-13-2013, 07:56 AM
My expierence with clutches the car either slipped or was not driveable at all. Never knew it was possible to drive with a flat dead clutch.
Old 04-14-2013, 08:05 AM
If the master cylinder ran dry then you have a leak. No where for that fluid to go but out. You said you drove it home in 1st gear so the problem is the clutch wont release. Can you pull the pedal back up by hand? The slave cylinder has a bleeder valve so it should bleed by gravity. No special tools needed to bleed. They sell rebuild kits for the master and slave cyls. They even sell the hose. Simple, single piston cylinders and as long as the bores aren't pitted you should be OK.
