Could I put a 06-09 Impala Radio in an 04?
I have a 2004 Impala LS. One feature I wish it had was an aux input for a portable mp3 player so I didn't have to use an RF thing and get kind of bad reception. I'd rather have a line in. I don't like after market radios because they don't look right being 1x DIN and the weird work arounds for the stereo controls on the steering wheel. Also, I used to have one in this car and it had to stick out of the dash about an inch to make up for the depth, which I thought looked bad.
I was just looking at this ad... http://www.ebay.com/itm/360519362567 I think cosmetically it would look pretty close to factory if someone didn't know what a factory radio looked like in an 04. Would it work in an 2004? Would it directly interface or is it not compatible at all because it's not meant for a 2004? I know I would at the least, I would have to take it to the dealer and have it programmed. (I originally changed out my factory radio when the car was new to an after market and sold the original one. Then the after market radio failed and I bought another factory one and had the dealer program it to my car. FYI) |
Re: Could I put a 06-09 Impala Radio in an 04?
reading thru the ad I found this...
Or better yet call or drive by the Chevy dealer nearest to you and inquire about it, I'd rather take their word for it...
---------------------------------------------- Current Rides: 2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4 ________________________________________ Past Rides: 2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI 2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI 1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL ---------------------------------------------- |
There are also some people on ebay that are modifying older radios, putting aux inputs on them. You could see if anyone has done that for your model radio.
I ended up using one of these: -ISIMPLE-IS31-Universal-Auxiliary-Audio-Input-For-All-Fm-Radios- It works pretty well, and it was the most cost effective solution for a stock radio without an AUX Input... it works with most radios and manufacturers, it blows any t transmiter type out of the water and gives "almost" CD sound quality depending on your location and setup.
10 hours away from John Deere master certified also master certified ASE tech. Exp. in both. Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training Gave up wrenching for "Greener Pastures" Current job: RN 2010 Silverado Z71 5.3L 65xxx Wife's 2007 Suburban 1500 LTZ 5.3L 102xxx |
It works really well, sound is clear and strong, close to CD Quality, which may be because I'm listening to MP3s which loose sound quality when converted...
Only problem I have (may be different for your location) is that my car has an amplified antenna and now FM Radio reception is really low. Thankfully the radio station I listen to the most comes in strong. If you have a an amplified antenna, a lot of low signal stations and listen to radio most of the time, this may not be the best alternative! Still I recommend it as a budget option to RF units, it sure beats them all! But every other weak station cannot be received now!
Give one of these a shot.
An easier way to put an "AUX" jack in your current radio is buy an FM Transmitter and set it to an unused spot in your FM radio. Saves a lot of money and the replacement radio may not work since the 2004 Impala used the VIN number in the security to work in your car. So if your current radio was stolen it would not work in another car. It all has to match.
The sound from a transmitter is orgasmic......... John
Happiness is driving a Chevrolet! |
