Old 04-08-2013, 08:10 AM
zip316 zip316 is offline
Driver side lock prolems etc.
Hi to all,
The problem I am having with my 2009 Grand Caravan SE is the drivers door controls stopped working. I cant use the power windows locks or door locks and the background light is off also, the front passenger side and middle row locks etc work.
On the driver door the only things that work are the 2 back vent windows. Has anyone seen this problem or had it , thanks in advance for any help.
Old 04-08-2013, 02:17 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Driver side lock prolems etc.
Zero experience working on 5th gen vans but looking at a wiring diagram, door power functions are controlled by left and right door control modules. They receive power from the TIPM - your fuse box. 25 amp fuse J4 in the TIPM powers the driver's door module. If the fuse is good I would suspect a bad module or a wiring problem. May be as simple as a loose door switch panel connector. Your rear vent windows don't use a dedicated module.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 04-08-2013, 02:27 PM
Thanks for your reply, I have called the dealer and they are talking 90+$ just to look at it. I guess I better find out where the fuse box is and check them lol.
Old 04-08-2013, 02:31 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The TIPM (Totally Integrated Power Module) is under the hood near the battery.
The Following User Says Thank You to RIP For This Useful Post:
zip316 (04-10-2013)
Old 04-08-2013, 04:05 PM
Thanks, I need to find my old fuse puller and go to work. I guess it is a love/hate relationship with these newer vehicles I used to know my way under the hood. These newer vehicles are way too complicated for me.
Old 04-09-2013, 06:57 PM
How do I check the module ,do I have to take the door panel off or can I lift the thing that has the window buttons etc?
Old 04-10-2013, 05:39 PM
hundahunta hundahunta is offline
you also may want to swap your door modules left and right front doors
The Following User Says Thank You to hundahunta For This Useful Post:
zip316 (04-10-2013)
