Old 04-08-2013, 12:21 AM
roque11 roque11 is offline
So yet another problem
I notice when I use the windshield wiper fluid my car will stall for a bit, but get back to running normally once it seems things dry off. It's like whenever you drive over a big puddle how it stalls and you have to wait a little to get going again or when you restart. What can this be? Man, I have so many problems with my car as people can see with my posts. I wish I had what was needed to get something new. I'm screwed.
Old 04-08-2013, 07:14 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: So yet another problem
Does the washer fluid spray on the windshield with good force, or does it just kind of trickle out of the nozzle? If you just get a trickle, then either some of the fluid may be spraying on an electrical unit under the hood, or you might have a weak charging system.
-Rod
Old 02-08-2014, 10:09 PM
taurusffv taurusffv is offline
I thought I had a leak in the washer fluid reservoir, but it turns out that my feeder hose was cut/separated and I was unloading a bottle worth of fluid under the hood. I bought a tiny cheap little plastic doohicky to join up the two ends of the hose and it worked for a short period of time before the water pressure caused it to pop apart again so I also taped the joint and now its fine. So open the hood of your car, have someone activate the fluid, while you watch under the hood to see what's happening.
