Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 04-06-2013, 10:13 AM
LS813 LS813 is offline
Degas bottle question
I am trying to bleed the coolant. I noticed where the top hose connects, the metal tube inside the tank is no longer connected. its just laying inside the degas bottle. Could this be the reason I am having such a hard time bleeding the air out?
Old 04-07-2013, 10:59 AM
Re: Degas bottle question
Guess my question is. Does the upper hose thats connected to the degas bottle serve also as a suction line? Will it also take coolant from the tank?
Old 04-07-2013, 11:48 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
What year is your LS, and which engine does it have?
-Rod
Old 04-07-2013, 01:14 PM
2001 3.9
Old 04-07-2013, 01:44 PM
I'm thinking that this is the reason I can't bleed the system properly. If I open the cap on the Degas bottle and push down on the radiator hose, I can here air being pushed out and sucked back in. I think the metal down tube is meant to keep that line submerged in coolant. Being its broken off its above the coolant level, and can draw air back into the system. Am I thinking correctly?
Old 04-07-2013, 08:37 PM
shorod's Avatar
SHO No Mo
According to the factory service manual for your 2001:
"The degas bottle:
  • provides a location for system fill.
  • contains coolant expansion and system pressurization.
  • provides air separation during operation.
  • replenishes the engine coolant to the system."
I no longer have an LS that I can use as a reference, but your suspicion sounds reasonable.
There appear to be 3 hoses connected to the degas bottle. It appears one is the inlet to the bottle, top, and two returns, lower. The inlet hose is connected to the thermostat housing. The return hoses are y-ed together an attached at the DCCV.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
LS813 (06-13-2013)
Old 04-08-2013, 10:13 AM
joegr joegr is offline
Yes, you are correct that this is your problem, and it is a known failure mode of the degas bottle.
The hose that connects at the top is the engine air bleed. Any air trapped in the engine should eventually come out here. When the engine cools down, it sucks coolant back in through that metal tube. Since your tube has disconnected, air is being sucked back into the engine instead.
The Following User Says Thank You to joegr For This Useful Post:
LS813 (06-13-2013)
Tags
air , bleeding , bottle , degas
