Old 04-06-2013, 02:40 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Unhappy Getting Fuel in cooling system-Power Stroke
Each time after running engine and letting cool down, when I check cooling system I find approx. 1/4-1/2" of fuel in the radiator. ANY ideas?
This is a late "90's vehicle.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 04-06-2013, 08:53 AM
DeltaP DeltaP is offline
Re: Getting Fuel in cooling system-Power Stroke
Most likely cracked head (s). Slim chance of injector cups/ injector O rings failure.
Old 04-11-2013, 09:34 PM
jyount jyount is offline
Late comer, sorry. I would figure out some way to put some REGULATED air hose pressure in the fuel rails to isolate it. If you are doing the work I would def. advise low to high difficulty. Orings - cups - head. Would sure suck to yank a head and find a 10 dollar oring kit is all you needed. Theoretically the fuel/coolant should never see each other, that is the whole idea of the cups, but stranger things have happened...
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
