Old 04-05-2013, 08:02 PM
guitarfish's Avatar
guitarfish guitarfish is offline
New caliper bad?
Long one, I'll try and condense.
I've had to replace the left rear brake caliper on my '08 Prix a couple times in the last few years. The factory caliper wouldn't release when I applied the parking brake. Replaced it with a reman from AutoZone. About a year later, the AZ caliper was doing the same thing, so I replaced it again (warranty). While at it, I replaced the parking brake cable on that side, as it was not moving too easily either. Once this repair was done (18 mos ago) everything worked like a champ.
Well, son of gun if the AZ caliper isn't locked up again! Unbelievable. Put the e-brake on, release, and the wheel is LOCKED. Had to use a hammer to get the caliper to release.
ANYHOO - replaced the caliper again this week (warranty). Parking brake not seized anymore, But now I have a new problem - the brake pedal goes down WAY too far. I thought maybe I didn't bleed the brakes correctly, so I redid that tonight, no change.
OK, scratching my head here. Check this out - I spin the wheel with my hand and while it's spinning I run over and jump on the brake pedal. The pedal is way down, and the wheel continues to spin for about a second, than instantly stops.
It seems to me like something in the new caliper is bad. It's "popping" into action about a second late. Make sense? I'm thinking I should swap this caliper again.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
1994 GP SE - 231,000
1997 GP GT - 134,000
1998 GP GT - 225,000
2002 GP GT - 222,000
Old 04-05-2013, 08:45 PM
Tech II Tech II is offline
Re: New caliper bad?
It's possible you have been replacing the calipers for nothing.....I think on this year vehicle, the caliper is not the e-brake....the e-brake is actually inside the rotor.....or rather, underneath the rotor.....
If the e-brake cable is attached to a lever in the backing plate, and NOT DIRECTLY TO THE CALIPER, that may be your problem......on this type of e-brake, there is a brake shoe that expands and grabs the inside of the rotor, similar to a drum setup....
one way to check this is, when you apply the e-brake and release it, if the rotor does not move, collapse the piston into the caliper....if the rotor still doesn't move, it's the e-brake mechanism under the rotor....
As for the low pedal, it could be air, a weak rubber brake line, the caliper, etc.
Old 04-05-2013, 08:50 PM
guitarfish's Avatar
On this car, the e-brake cable is attached directly to the caliper, not the backing plate. Believe me, I've been changing calipers for good reason. The new ones I can move the eBrake mechanism by hand and it snaps back into place. On the bad ones, it's corroded so bad it hardly moves at all.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
Old 04-06-2013, 11:01 AM
OK, I just thought this had the drum design e-brake.....
Old 04-08-2013, 12:40 PM
guitarfish's Avatar
Just thought I'd post back, yep, the new caliper was faulty. Swapped with another, all good now.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
