Old 04-05-2013, 03:00 PM
hobitopia hobitopia is offline
97 k2500 Brake issue
Hey all, I recently replaced my brake booster, since the old one was leaking vacuum.
Now that I've got a new one in, the brakes won't immediately release if I depress the brake pedal too hard, and sometimes it will require me to jiggle the brake pedal, or even put my foot behind it and pull it up.
Does this sound more like I just got a faulty booster? It's only a NAPA rebuild. Or does it sound like the new booster is potentially causing caliper issues?
Old 04-05-2013, 04:58 PM
j cAT j cAT is offline
Re: 97 k2500 Brake issue
a bad leaking brake booster would cause a very hard brake pedal. since you messed with the linkage to the pedal my guess is you put the new one on wrong or the booster is the wrong one or broken / bent some how.
Old 04-05-2013, 05:20 PM
gremlin96 gremlin96 is offline
retest the buster and see if you got a bad one.
Old 04-06-2013, 09:19 AM
DeltaP DeltaP is offline
Possibly the rod between the master cyl and booster is out of the booster socket. Did you make any adjustments to the rod?
Old 04-06-2013, 10:30 AM
I didn't make any adjustments to the rod. I just took the old one out and put the new one in.
Old 04-06-2013, 01:00 PM
match the old one with new that it is set to the proper dimension. also disconnect and see if the brake pedal sticks.
