Old 04-04-2013, 02:38 PM
tpliquid tpliquid is offline
Send a message via AIM to tpliquid
Paint booth, need some feedback
I drew up a quick mockup of a paint booth that I like to build
I plan on using 2 computer fans 120mm ones. I am not sure if they will even work, the fans are rated at 45CFM.
my dimensions are 15x15 inch base. about 10 inch high.
There will be hinges on all the pieces so it can be folded when I am not using it.
friends let friends drive benzes
Old 04-04-2013, 03:42 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
Re: Paint booth, need some feedback
setup looks good, though seems to be a bit too small.
olly olly oxen free
Old 04-04-2013, 03:51 PM
MerlinPro MerlinPro is offline
A. Computer fans not rated for flammables.
B. You need near 200CFM and a larger opening.
Merlin
Old 04-04-2013, 04:08 PM
thx for the feedback. I am mainly using it for 2 pack clear. I still need fans rated for flameables?
Old 04-04-2013, 05:32 PM
Do the computer fans have protected pole motors??
Merlin
Old 04-04-2013, 06:13 PM
freakray freakray is offline
AF Modelrater
If the computer fans are brushless, they will be fine. I've used them in the past for a paint booth with no issue.
Dimensionally you're cutting yourself shy, my booth is 24" wide x 18" tall and still can feel small when doing car bodies.
AF User Guidelines
The Following User Says Thank You to freakray For This Useful Post:
tonioseven (04-12-2013)
Old 04-04-2013, 06:14 PM
Archibaldi's Avatar
Archibaldi Archibaldi is offline
Hi !
Your set-up won't suck sprayed paint, 'cause it need a flap,
and the funnel, leading to the fan.
Here is my booth, installed fan is 90 cubic m/hour.
Ruler is in decimetres.
Hope that helps.
Old 04-05-2013, 12:48 PM
Kaj45rpm Kaj45rpm is offline
Use an extractor fan kit for a shower. I built one, it has an induction motor and works perfectly. Whole kit cost less than 50 quid.
Old 04-06-2013, 08:30 AM
RunFlat's Avatar
RunFlat RunFlat is offline
Yes a bathroom vent fan will work and there are some helpful DIY on YouTube.
Old 04-08-2013, 03:09 PM
GirchyGirchy's Avatar
GirchyGirchy GirchyGirchy is offline
Read up, the bathroom fans aren't rated for explosion proof fumes. Most go with a bilge blower fan for boats, used to ventilate bilges, fuel vapors from the engine compartment, stuff like that.
Old 04-26-2013, 02:08 PM
eyckles's Avatar
eyckles eyckles is offline
Hi guys,
I have a quick question. What does CFM mean?
Also are these fans any good for a spray booth. They are brushless:
http://www.power-on.com/sunon-kd1209ptb1-3w3p-fan.html
http://www.thermalfx.com/fans/120/KDE1212PMB2-6A.html
How many do i need for a 60cm x 60cm booth?
Best regards,
Lesley
Old 04-26-2013, 02:16 PM
I doubt it. The first one is direct current and small.
CFM means cubic feet per minute and is a measure of air flow. Higher numbers mean more air flow.
A booth your size works best with 200 or so CFM.
Merlin
Old 04-26-2013, 02:30 PM
eyckles's Avatar
Hi Merlin,
The second fan link has 98,0 CFM, so if i install 3 or 4 of them with a potentiometer to control the suction. Would that be enough. Than i almost have 400 CFM.
Best regards,
Lesley
Old 04-26-2013, 09:22 PM
roydion78 roydion78 is offline
Cool car and a very nice build!
