Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-04-2013, 08:25 AM
pvisser pvisser is offline
Send a message via MSN to pvisser
Air Ride
2007 SV6 with air ride.
Compressor works great.
Air ride is ok, except, after the van is unloaded, it takes days if not weeks to come down and be level. Then it's fine, until you add a load in the van, and we start the problem all over again.
It fills the shocks so much that the van thumps over bumps cause the shocks are maxed out.
Paul
Old 04-04-2013, 11:02 AM
Tech II Tech II is offline
Re: Air Ride
If I remember right, the air system is tied into the PCM or BCM(this should set a code)...... scan tool can read what the level of the car is, and if the vent solenoid is being commanded off/on......
One thing you can try is pop the lever from the level sensor from it's attachment to the body, and move it to the extreme ends.....one way commands the pump on, the other should shut the pump off and open the vent solenoid.....if you hear the solenoid click open, but the car does not drop, then that is your problem......there will be a delay of up to 20 seconds when moving that lever......
Unfortunately, without an expensive GM scan tool, you can't read where the problem is.......the level sensor, or the vent solenoid......in some cases, the solenoid is integral to the compressor and the whole unit has to be replaced....
To get that rear end down, just remove one of the air lines to the air shock/strut, and this will lower the vehicle......usually is a silver clip that you rotate 90 degrees and then pull the line off......rotate it back and push the connection back on the shock/strut....
The Following User Says Thank You to Tech II For This Useful Post:
pvisser (04-04-2013)
Old 04-04-2013, 06:37 PM
Lol. Never occurred to me to try to move the lever manually...
Thanks. I'll give that a shot.
If the relay clicks to lower, but it doesn't, would that likely be a blockage then..?
I'll report back
Paul
Old 04-05-2013, 03:40 PM
Re: Air Ride
Could be a bad vent solenoid....like I said, I am not sure if it is integral to the compressor.....if it is, the whole unit has to be replaced....
Old 04-08-2013, 12:32 PM
So tested it out.
I am able to get the compressor on, but not drain the air.
Any ideas where the solenoid may be?
Paul
Old 04-08-2013, 02:22 PM
Re: Air Ride
Think about it......air lines come out of the compressor to the shock/struts.....no place else....
It has to be in/near compressor.....but like I said, the bad part is, it may be "integral" to the compressor.....but remember, it has to get a signal to open.....
Old 04-08-2013, 03:27 PM
Ah I c.
I was able to pull a code from the inflator.
DTC32 - which is the inability to return to level from full inflation.
Looks like the exhaust solenoid is built into the head of the compressor.
Bummer..
Paul
Old 04-08-2013, 08:12 PM
Re: Air Ride
You still have to examine the circuit to the ex solenoid, before you condemn it.....
Old 04-08-2013, 08:18 PM
watkiichael6 watkiichael6 is offline
Re: Air Ride
Time to get down to business.
Old 04-09-2013, 10:17 PM
Yup.
Just gotta get my hands on some schematics..
Paul
Old 04-10-2013, 01:34 PM
Re: Air Ride
OK, looking at the wiring diagram, with key on, if you disconnect the harness from the compressor, and jumper harness connector "C" to terminal "C" of the compressor, and then jumper harness connector "G" to compressor terminal "B", this powers and grounds the vent solenoid......if the vehicle lowers, there is nothing wrong with the solenoid....chances are it's the level sensor or the wiring/connections to it.....
Old 04-10-2013, 09:12 PM
Wow Tech II.
Thanks. That's way more than I expected.
Will work on that as soon as this freezing rain is outta here.
Paul
Old 04-11-2013, 08:07 AM
Re: Air Ride
Here is an alternate test......key "on"....
Disconnect the level sensor.....jumper harness connectors "A" to "C"(this grounds the solenoid, it is powered by the ELC fuse).....when you do this, you should hear the air exhaust.....
Old 04-21-2013, 09:34 AM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: Air Ride
Paul
I know it can't be this simple, but ours started doing what you describe after about 6 years on the road. It would continue to pump up, but not exhaust the air. By the time I had dropped my daughter and her friend off at Canada's Wonderland and drove home the shocks were close to fully extended. I was looking down at the road the back end was so high.
When I crawled underneath, the rod that connects to the leveler sensor was disconnected. Actually, it was broken off and I had to clean both of the balls that it snaps into, repair the socket ends and then grease them.
Your problem does sound different though.
If I had my way, every GM car I ever owned would be a Chrysler!!!
Old 02-08-2014, 10:50 AM
Re: Air Ride
So, finally pulled the connector off the levelling module.
When I short across a and c I can hear the relay click, but the air is not released.
When I reconnect to module, I expected to hear the relay click but it doesn't.
