Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 04-04-2013, 07:38 AM
jevon09 jevon09 is offline
Question 1986 Monte carlo SS engine swap
I have a 1986 monte carlo ss with the factory 305 hp I want to swap it with a 6.0 gm ls with 325 horsepower out of a chevy Silverado.....from my understanding my car weights 3,387 pounds which is almost less than half of the weight of a Silverado?
I want to know since my car is lighter will it produce more than 325 horsepower with the factory 6.0 gm ls engine?
Old 04-04-2013, 08:33 AM
maxwedge maxwedge is offline
A990 racer
Re: 1986 Monte carlo SS engine swap
Welcome to AF. How does the weight of the car change an engine's hp?
Old 04-04-2013, 08:51 AM
Yes that's the question I'm asking.
Old 04-04-2013, 11:11 AM
Tech II Tech II is offline
Good one Max!
Old 04-04-2013, 11:47 AM
A990 racer
Not sure where you are going with this but 325 hp is the same whether it is sitting on the ground or in a car/truck. Obviously your much lighter MC would be way quicker than the truck the engine came out of.
Old 04-04-2013, 12:34 PM
And what can I take off are add to this motor in order to gain more horsepower? The basics
Old 04-04-2013, 06:44 PM
A990 racer
Unless you really want to race competively I would leave it alone, just good exhaust and gearing, you know you will need a compatable trans set up as this is an all computer controlled engine so plenty of harness changes will have to be done.
Old 04-04-2013, 07:01 PM
I have 3.73 gears and planned on putting a set of 243 heads with a ls3 are ls6 intake with a street cam and as far as transmission I planned on going with the 4L60e are the 700r4. What do you think about the combination if I didn't stay stock?
Old 04-05-2013, 09:17 AM
A990 racer
Sounds like a plan.
Old 04-05-2013, 11:23 AM
Do out think ill get anywhere from 425-500 horsepower when I'm done and I also plan on putting long tube headers on with straight to the back true duals and.maybe flowmaster super 10 series mufflers
Old 04-05-2013, 07:18 PM
A990 racer
I don't with stock heads you will reach those power levels. Check some of the LS build- ups by various magazines online.
Old 04-05-2013, 08:17 PM
OK kool thanks
Old 04-08-2013, 11:11 AM
So where do you guess my horsepower will Max at?
Old 04-08-2013, 06:38 PM
A990 racer
What are the specs on this street cam?
Old 04-08-2013, 08:19 PM
watkiichael6 watkiichael6 is offline
Time to get down to business.
