Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-01-2013, 09:42 PM
ananias2006 ananias2006 is offline
Missing when it rains
I have a 1999 Tahoe LT, 4Dr, 190,000 miles, however new engine - less than 20,000 miles on it. Runs fine except when it rains, has rained, or during snowy weather. In wet, or even high humidity conditions - it will run rough - seems to miss, or hesitates - just runs really rough. I realize this sounds like a distributor leaking, however it is not. I'm stumped, and so is my garage. It doesn't even have to be raining; if it has rained, it will begin to run rough - and will even run rough for about 30 minutes driving time the day after it was driven in wet weather. The problem has persisted now for several months, and I can't figure it out. I can put it in neutral, rev the engine and it will do the same thing. I have a cold-air intake on the vehicle also, however was installed long before this problem began. Although it has persisted for several months, it does appear to be getting worse lately - the rough running appears to be more severe than it was when it first started. Any ideas will be appreciated.
Old 04-02-2013, 09:04 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Missing when it rains
Plug wires ,dist, cap, coil or spark plugs.
Cracked or drawing moisture.
MT
Old 04-02-2013, 10:23 AM
aleekat aleekat is offline
If it rains at night, start the car up and look under the hood for a arc, short, around ignition system. You should be able to see it. Or use a plant mister bottle. Duplicate the wetness. But MT-2500 is leading you down the right path.
Old 04-02-2013, 01:21 PM
j cAT j cAT is offline
so it runs bad when wet out . what did the replace or check ?
this is an old style 350 cu engine .
