Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-31-2013, 01:39 PM
Black Midnight Black Midnight is offline
car revvs itself while in park
My car seemed to drive home fine but when I put it in park to open my garage it started revvin really fast and the check engine light came on. I could barely get it into drive and then it didnt hardly want to stop once in drive. Anybody have this issue?
Old 03-31-2013, 01:57 PM
aleekat aleekat is offline
Re: car revvs itself while in park
codes?
Old 03-31-2013, 02:19 PM
I dont know how to do codes and is it safe to start up again?
Old 03-31-2013, 02:34 PM
Really sounds like it's unsafe to drive. You didn't give the year. You need a code reader. Most auto parts stores will read the code for you but it's not a definite "replace this" and all will be fixed. It's a diagnostic tool.
Old 03-31-2013, 02:47 PM
the year is a 95 plymouth neon 4cyl with approx 99000 miles on it
Old 03-31-2013, 03:31 PM
hundahunta hundahunta is offline
check for a vacuum leak
Old 04-01-2013, 01:13 AM
If he has no clue how to check codes, vacuum leak checking doubt it..
Old 04-04-2013, 01:57 AM
ok mechanic took it in to look at it, they came up with a code 11 and they couldnt find a vacuum leak. They claimed it could be the timing belt, but I replaced that back in 2002 and I have only put on 25,000 miles since then. So could the timing belt really be bad if it isnt that old? Thanks for any help that u can give me
Old 04-04-2013, 11:55 PM
I would think even if your timing belt jumped a tooth it should not have a high idle
The Following User Says Thank You to hundahunta For This Useful Post:
Black Midnight (04-05-2013)
Old 04-05-2013, 12:19 PM
The car seems to be working fine now so I am not sure what caused the incident or if it will come back again
