Old 03-30-2013, 10:19 PM
ka9mgd's Avatar
ka9mgd ka9mgd is offline
Registered User
odd problem
I have a 96 Park Avenue with a firewall that is disintegrating from power steering fluid being thrown on it from a pump shaft seal leak. I have replaced the shaft seal. Now what can I repair the firewall with that has mostly broken and fallen off behind the power steering pump? I was thinking about using undercoating sprayed on the firewall unless someone has a better idea.
Old 03-31-2013, 09:51 AM
brcidd's Avatar
brcidd brcidd is offline
Re: odd problem
If you are referring to the rubber/plastic HVAC box insulator- (as to what is deteriating)- they all do it- regardless of fluid spraying on it. They crumble apart- especially if you have to get in there to work on anything- there should be metal underneath it-- as a matter of fact, there were model years when the insulator was not used- just the metal was there- I usually just pull it off and consider it as good as a model year or two earlier...
I can't imagine a metal firewall rusting out with oil based fluid spraying on it....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-31-2013, 01:48 PM
ka9mgd's Avatar
Registered User
Re: odd problem
There is not any metal under it, just yellow insulation.
Old 06-08-2013, 10:25 PM
Mastercarpentry Mastercarpentry is offline
Re: odd problem
My 94's simply melted from exhaust manifold heat on the bottom- the top seems good as new. No metal liner here either. Been like this 4+ years with no problems so I ain't gonna fix what ain't broke.
73deKG4FQG
Phil
