Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-29-2013, 10:28 PM
gearwrench68 gearwrench68 is offline
2001 ram 4x4 down shift issue
Helping a neighbor out here, he has a 2001 dodge ram. While driving with the cruise at about 60 miles per hour and pulling a moderate hill it down shifted out of o/d into 3rd then quickly down to 2nd and would not up shift again until engine was restarted. a few days later it would not shift from 2nd to 3rd unless engine was restarted. No check engine light, nor any codes with code reader. any ideals would be appreciated.
Old 03-30-2013, 08:07 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2001 ram 4x4 down shift issue
This is gonna sound odd but I've read of stray voltages from bad alternators messing with the transmission signals.
Set your digital volt/ohm meter to read AC millivolts then with the engine running, probe the battery terminals. If you don't have one, check with the local chain type auto parts store for one to borrow.
Acceptable AC volts are .2 to .3.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
The Following User Says Thank You to Chris Stewart For This Useful Post:
gearwrench68 (03-30-2013)
