Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-26-2013, 05:49 PM
nivek70 nivek70 is offline
oem fog light wiring
i just installed oem fog lights that i removed from an 02 dodge ram SLT to my 08 dodge ram 1500 (no fog lights before, just the grills in the bumper holes) The lights installed easily. I used the wiring harness that connected the 2 fog lights from the old truck and to my surprise there was a wiring harness/plug on the 08 exactly the same as the 02, so i connected it together. The wiring went from the connector and travels up and then dissapears into a spagetti maze of wiring! What im wondering is- since there was a fog light wiring harness to connect to behind the bumper, is it as simple as installing a switch inside the truck once i find the end (if there is an end under the dash somewhere) Any experience, opinions would be appreciated.
Old 04-20-2013, 10:50 AM
Re: oem fog light wiring
hello,anybody out there!!
Old 04-21-2013, 06:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
To operate the fog lights on my '01, you very easily pull the light switch knob out.
You may have to buy a fog light light switch.
How'bout it '08 owners?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
