Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-26-2013, 01:04 PM
rkvons's Avatar
rkvons rkvons is offline
Attaching Cat Converter
Anybody know the torque specs for the catalytic converter attaching to the exhaust manifold flange. It has a ring that needs to be compressed into a channel. Thanks.
Old 03-29-2013, 09:41 PM
LMP's Avatar
LMP LMP is offline
Re: Attaching Cat Converter
What year?..In my case (93) the "donut" that seals the exhaust manifold and the exhaust pipe (leaing to the cat) is pressed in place by the springs loaded on the retaining bolts, not by the bolt itself.
My manual says front exhaust pipe to manifold bolts 22 lb.ft
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 03-30-2013, 04:35 AM
WelmoedJ's Avatar
WelmoedJ WelmoedJ is offline
LMP: That also applies to the 95 3.8L models
Welmoed
De Lorean DMC-12 1981-11
Toyota Prius III 2009-07
Old 03-30-2013, 10:05 AM
rkvons's Avatar
Crap! I was assuming everyone knew about my vehicle. How dumb of me. It's a '98.
Old 03-31-2013, 02:33 PM
LMP's Avatar
LMP LMP is offline
OK..from what i see in the rockauto catalog, the setup is different...with a braided link and a much thinner seal ring ...so...I do not know...either way the bolts are about same size so they can probably be torqued in similar range as stated above..
Old 04-03-2013, 12:43 PM
rkvons's Avatar
I put on a whole exhaust system. I did not use a torque wrench on those bolts. I basically gave it a pretty good snugging. Probably was around 20 ft-lbs. It turned out great.
