Old 03-25-2013, 08:15 AM
reefgeorge reefgeorge is offline
Coolant leak
Have a small coolant leak. The level is dropping and I can smell it but I cant find it. The radiator was new at 100K miles and the heater core is bypassed. No evidence on or near the hoses, water pump or radiator. Getting ready to replace all the hoses because they are overdue but I would like to find the leak(s) first. Any ideas?
Thanks
2002 Blazer, 4 dr, 2wd, 199K miles
2003 Rav4, 4 cyl, 239K miles
2012 Mailibu, 4 cyl, LTZ, 85K miles
Old 03-25-2013, 09:56 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Coolant leak
Thanks
Test before replacing hose and then after .
Get some coolant leak test dye and a pressure tester.
Preasure test cold and warm and hot.
MT
Old 03-30-2013, 05:36 AM
Re: Coolant leak
Is the intake manifold coolant leak internal or external?
Old 03-30-2013, 09:17 AM
MT-2500's Avatar
AF - Advisor
Re: Coolant leak
Can be either one.
Watch engine for coolant in it if internal.
For external leaks pressure test coolant system cold and warm and hot.
If you use coolant leak dye test stuff and have a internal leak it will show up in engine oil test.
MT
Old 03-31-2013, 10:54 AM
Re: Coolant leak
Thanks, I will get the dye in the system next week. How long does a water pump usually last? Mine has almost 200,000 miles on it.
George
Old 04-01-2013, 05:11 PM
MT-2500's Avatar
AF - Advisor
Re: Coolant leak
They last a lot longer that they used to.
MT
