Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-24-2013, 06:47 PM
nova1313's Avatar
nova1313 nova1313 is offline
97 Spyder GST - Battery draining
Hello all, long time since I last posted! My battery has been draining constantly as the car sits.
Got a new battery today and put a meter between each positive lead as I put it on. My issue may have been the last battery but I just want to make sure what I see now is normal.
Main connection - no draw.
4 white connections (each bonded to each other)
--1 lead no draw
--2nd lead .03 amps and horn beeps when I plug it in. My guess was this is the security system?
Amp connection - .03 amps draw. This should turn on when the car stereo does I have the trigger lead connected. I found it odd that this was drawing slightly. Does this seem normal?
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 03-26-2013, 07:03 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 97 Spyder GST - Batter draining
You should be testing your amp draw on the negative battery post between the terminal and the cable not on the positive side. You should be about 30-50 milliamps total draw when the car is off and all the lights have turned off. Any more than that and the battery will be drained. Then you start pulling fuses and unplugging things until the draw goes away.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
