Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-24-2013, 11:52 AM
Scotty89's Avatar
Scotty89 Scotty89 is offline
2003 Ram 4.7 Rough Idle
I have a 2003 Ram 1500 with the 4.7 L that has a rough idle at a stop light or sign. Sometimes it idles bad enough that it dies but it will restart. It doesn't set any DTC's. I have tried a new throttle position sensor and downstream O2 sensor. If i unplug the downstream O2 sensor the truck seems to run fine. Any one have any ideas?
Old 03-24-2013, 08:14 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2003 Ram 4.7 Rough Idle
I've read where cleaning the throttle body/butterfly with some carburetor cleaner sprayed on a shop rag and wipe the parts clean working on a 5.9L
You might clean up the Idle Air Control (IAC) valve while you have things exposed.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 03-24-2013, 11:08 PM
Scotty89's Avatar
I've taken the IAC out and looked at it, there wasn't much of anything on it and it seemed to move easy. I tried to clean it the best i could. I opened the throttle blade and there wasn't much build up on it either.
Old 03-25-2013, 07:29 PM
AF - Advisor
Anything improve after cleaning?
Old 03-26-2013, 07:16 AM
Scotty89's Avatar
No improvment after cleaning IAC.
Old 03-26-2013, 06:48 PM
AF - Advisor
How many miles on this vehicle & how many since the last tune-up?
You might try going to a chain type auto parts store for a free scan to see if there are any pending codes, which don't turn on the Check Engine light.
Old 03-26-2013, 07:53 PM
Scotty89's Avatar
It has around 100K on it and my friend has owned it since May and hasn't had any issues with it til recently. I'm not for sure when the last tune up was. I have a code reader and the only code that has been resetting in the system is a code for the oil sending unit which i know it needs replaced.
Old 03-27-2013, 07:56 PM
AF - Advisor
Have you set your scan tool for Live Data, drove the truck, stop to start the engine missing then see what the Live Data/current conditions are?
What do you think about a fuel pressure issue?
Old 04-02-2013, 08:17 AM
Scotty89's Avatar
I updated the pcm to current software level and had her drive it home. She has been driven it for a week and it is driven better. She says it sputters maybe once when she drives it and it has died only once. Still no DTC's. I havent had the chance to check fuel pressure. Has anyone seen any purge solenoid issues on these sticking open?
