98 grand prix fuel pump want run
hello checked all fuses pump is good ran wire from battery and pump is good but when turn key on pump want run and dont have no power on the injector wires at all tried starting fluid and nothing just cranks ran fine pulled in drive way shut it off and whent back and wont start.it has a remote starter and theft out fit that looks like some one installed could that have anything to do whith it.thanks for any help.it has the 3800 180000 miles
Re: 98 grand prix fuel pump want run
hello checked all fuses pump is good ran wire from battery and pump is good but when turn key on pump want run Disconnect harness to tank and attach test light to the half of the harness going away from the tank, on the f/p circuit......turn key to run....does the test light light for two seconds? Crank vehicle......is the light on as long as you crank? Have you checked fuel pressure with a gauge? and dont have no power on the injector wires at all tried starting fluid and nothing just cranks There are two wires to each injector, the pink wires are always hot...are they? Disconnecting an injector harness and attaching a noid light to harness, does it blink when vehicle is cranked? ran fine pulled in drive way shut it off and whent back and wont start.it has a remote starter and theft out fit that looks like some one installed could that have anything to do whith it.thanks for any help.it has the 3800 180000 miles Sure it could....does the remote start work, or does the alarm work? If the injectors don't blink, it's possible the alarm system has something to do with it....it's possible a fuel enable signal is not reaching the PCM... Vehicle scanned for codes? Does the vehicle have spark? |
Fact you have a toggle switch, looks like you have an alarm or remote start in there......drop the hush panel underneath the drivers side of the dash and look for extra module/harness that is tied into the harness of the car.....usually will see "butchered" connections.....
If you find one, then it might have to be COMPLETELY REMOVED, and the wiring repaired..... Scanned for codes? |
