Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-20-2013, 03:00 PM
ChrisQ724 ChrisQ724 is offline
2010 Corolla Center Air vents don't blow
I recently purchased a 2010 Toyota Corolla. Over all good car and in pretty decent shape. The Only only issue I've found with it is the two center air vents are not blowing, nor does the a/c knob change the air flow. For example regardless of what air setting I have it on it's always the two foot vents and the outter door vents blowing.
Granted the air temp is fine. It responds to whatever temp I want it and it gets plenty cold. So does anybody have any idea if this can be resolved with a simple fix? Appreciate the help.
Old 03-21-2013, 01:48 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2010 Corolla Center Air vents don't blow
Sounds like the servo motor that controls that mix mode door is broken, the shaft that the motor connects to the door is broken, or the switch is bad. Key on & engine off with the fan speed knob on low, do you hear any motor whirring or clicking when you turn the knob? Sometimes you can hear it trying to move.
On my '03 Vibe (which is a Matrix), the fresh/recirc door servo wouldn't work when we got it and I was able to hear it trying to move. Turns out one of the gears inside the case had broken a tooth and kept it from turning.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-15-2013, 10:27 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
You can get under the dash on the drier side by the pedals and look at the heater box and see if the levers move when you change positions.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
