Old 03-20-2013, 01:56 AM
Jojo25ld Jojo25ld is offline
98 Pontiac gtp shifting problems
I have a 98 Pontiac gtp shifts good from first to second at about 15 mph but will not shift into third until I get speed up to 50mph and a high rpm shifts into all other gears after third at normal rpm and speed why does it not want to shift Into third correctly?????
Old 03-20-2013, 09:22 AM
Tech II Tech II is offline
Re: 98 Pontiac gtp shifting problems
Scanned for Transmission codes?
Put the car in manual first and drive.....then manually shift into second......then manually into third......
Did you "feel" the normal 1-2 and 2-3 shift?
Old 03-20-2013, 11:48 AM
It's normal from first to second the only problem is shifting into third it shifts perfect in every other gear I scanned the tranny shift silonoied A and something about TCC FAULT or something I'm not around where I have it wrote down
Old 03-20-2013, 11:49 AM
And yes I tried shifting manually it does the same thing
Old 03-24-2013, 01:13 PM
zepol zepol is offline
I am having the same issue with my 2001 GTP. One thing that I noticed is that while I am driving it the mph gage seems to work but as soon as I take my foot off the gas the mph gage drops down 0 mph even though I know I am driving faster than 5 mph. Does anyone know what this might be indicative of? Also the car seems to not slip as much when I am giving it more gas from the get go. If I slowly try to go from 1st, 2nd, 3rd, gear etc it seems to have a hard time getting to 3rd. Zep
