Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-19-2013, 02:44 PM
CvP CvP is offline
Exclamation 2002 Chevrolet Siverado Sputter
Truck hesitates when accelerating. It seems like gas is not getting enough gas to the point where the truck will finally stall out. I have replaced the fuel filter, ran fuel injector cleaner (briefly), and tried higher grade glass. After every episode, the truck starts up like a champ, but after 3-5 minutes of running, or a lot excessive speed, it starts to sputter. Could it be the fuel pump? The fuel injector? or Sparkplugs? I would really appreciate your suggestions!
Check engine light codes: P0171 (once) and P0174 (twice) and P1133 (once)
Old 03-19-2013, 03:00 PM
j cAT j cAT is offline
Re: 2002 Chevrolet Siverado Sputter
with a pressure gage you do the fuel pressure test. you must have more than 50 psi no less. if you run on empty alot the fuel pump is most likely going.
Old 03-19-2013, 10:25 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Change your fuel filter, check your fuel pressure regulator. As j cat stated above, check that fuel pressure.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Tags
2002 , chevrolet , chevy , engine , siverado
