Old 06-07-2003, 02:53 PM
crx hf crx hf is offline
Need Help with ROTOR
The disributor cap is off but the rotor wont come off.Ive swiched the rotor on my moms car and i never had his problem.
Old 06-07-2003, 02:54 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
righty tighty, lefty loosey?
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 06-07-2003, 02:55 PM
GTi-VR6_A3's Avatar
GTi-VR6_A3 GTi-VR6_A3 is offline
H4X0R T0 T3H M4X0R
Send a message via AIM to GTi-VR6_A3
what car does your mom have? civic as well? i would suggest tryin some WD-40.
-GTi-VR6_A3
-GTi-VR6_A3
Old 06-07-2003, 03:09 PM
She has a 99 GTP Grand Prix(supercharged).still cant get it off
Old 06-07-2003, 03:12 PM
GTi-VR6_A3's Avatar
H4X0R T0 T3H M4X0R
hmm you may have a case of OMS... old motor syndrom, parts tend to not wanna do what they are supposed to
-GTi-VR6_A3
-GTi-VR6_A3
Old 06-07-2003, 03:15 PM
dagoEF's Avatar
dagoEF dagoEF is offline
There is a little screw on the shaft that holds it in place, it might be facing down which makes it a little hard to see. It should be there. I had the same problem on my 90 hatch. What I did was put evrything back together start the car turned it off, pulled the cap off and the screw was facing up, luckily I only had to do this twice before the screw was facing up. Hope this helps.
Old 06-07-2003, 03:25 PM
redvalkrie's Avatar
redvalkrie redvalkrie is offline
Send a message via Yahoo to redvalkrie
Wink Hey!
Yup there is a little screw in there it requires an alan wrench it is very small and you should be getting a new one when you buy a new rotor!
U will see how small this little shit is. BTW make sure its on there good cause they do fall out, they make it feel like your timing belt just broke very horrible feeling when ur on the freeway!
Quick tip behind the drivers wheel in the wheel well there is a bolt sticking out you can move it wih a socket and it will turn ur rotor so you dont have to put everything back on and start the car!
Check it out!
(I hear what you are saying but I feel you are lieing to me, would love to say to BUSH!)
"Don't trip, skip, pinch your forehead"!
1988 CRX Si
2001 CBR 600F4i Silver & black FAST!
2004 Toyota Tundra (TRD)
2002 dodge grand caravan.
Old 06-07-2003, 03:50 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
Yea, thats a time saver....that would be the crank bolt. I believe its a 17mm hex bolt if I remember right.
There's nary an animal alive that can outrun a greased Scotsman!
Old 06-07-2003, 04:00 PM
dagoEF's Avatar
sweeet, I didn't know about the ckank bolt thhing, I'll be sure to do that next time.:ylsuper
Old 06-09-2003, 03:10 PM
redvalkrie's Avatar
COol!
Than-x I didnt know it was called a crank bolt!
1988 CRX Si
Old 06-09-2003, 08:49 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
If you leave your car in gear you could drift the car back or forward enough to get the rotor screw to point upward, or turn the crank pulley.
When you do this use the right sized hex wrench, too small and you might strip the insides of that screw which would be a major PITA to fix.
Also put some Loctite on the threads of the screw because sometimes vibration can make the screw come out, happened to me with my D15 and it fucked up my car.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Need Help with Rotor Replacement!! samsungg How-To's and Walk-Through's 2 05-23-2006 09:14 PM
Need help with some major problems with 95 probe Feicht Probe 5 09-10-2004 01:33 AM
Need Help With K2500 Front Rotor ... Please! Ace Greenberg C/K 6 05-12-2004 09:54 AM
Need Help Removing rotors/drums on 01 Grand Am Pontgr_am Grand AM 6 05-06-2004 07:35 AM
Custom CRX WIDEBODY, Need help with rims. Need some input. Psionic '88 - '91 Civic | CRX | Wagon | Shuttlee 12 12-19-2003 12:43 PM
