Old 06-07-2003, 02:20 PM
MR1337 MR1337 is offline
Exclamation Acura Integra '00 radio detaching help
kk I got all the stuff for my car ... set it all up (Integra '00) but I can't detatch the radio, is the standard one but since it is "Anti-theft" I believe it has some screws I can not reach from the back ... can any one help me out by telling me how to detach this radio out of the console?????
Old 06-10-2003, 06:24 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
i read this and thought i'm not touching this one. But here goes you must remove the dash sort of actually nevermind let's just say it's hard and if you don't know take it to a shop. IT is an isomount radio
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 06-11-2003, 01:41 PM
HookdUpTeg99 HookdUpTeg99 is offline
You don't need to take apart the dash at all...Just open the passenger side door, stick your head under the passenger side dash, and look behind the console for the screws (you'll need a flashlight). I installed my new system by myself and if I remember correctly, there are 4 screws located at the very back bottom of the stereo and are attached to a small steel crossmember. You should be able to see them and remove them with minimal problems. They are a b*@#$ to take out and even worse to put back in so pray that u never have to INSTALL it back like I had to once Hope you can work that out.
'99 Red Integra LS
- Ground Control Coil-Overs
- KYB AGX Adjustable Shocks
- 17" Konig Toxxins w/
205/40/17 Kumho Ecsta Supras
- Mid-Wing Spoiler w/ LED
- Injen Cold Air Intake
- Pioneer Head Unit w/ Animation
- JL Audio 250/1 Amp
- 2 10" Alpine Type-R Subwoofers
- Reverse Indiglo Titanium Face Gauges
- Hyper White Headlights
- Clear Corners
Old 07-27-2003, 11:58 PM
IchibanRuss IchibanRuss is offline
Cool Radio Security Code doesn't work?
arial
If you enter your radio security code and find that your radio still doesn't work:
1) The owner's manual say to "keep entering the code". This didn't work for me. The manual also says... after 10 attempts you "must leave the radio on for 1 hour", then try again. This in NOT entirely true!
2) Just unplug the battery again for about 10 min. Then re-connect. If your radio security code still doesn't work, TRY PRESSING THE CD EJECT BUTTON and CASSETTE EJECT button. This seems to have a positive effect on helping to clear the settings. Then enter your code again.
3) This routine worked for me. Maybe it will work for you.
95 Integra LS with B18 A1 VSS location? cwshifflett Integra 1 02-05-2011 08:32 PM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
94 Acura Integra HELM manual like new skola239 Classifieds 0 03-22-2009 09:56 AM
1995 acura integra need radio code k192 Interior | Audio | Security 0 02-21-2009 10:56 PM
Acura Integra '00 radio detaching help MR1337 Integra 1 06-11-2003 02:29 AM
