| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
Tamiya MP 4/4 with Top Studio Super Detail
Started this on Monday. This is by far the most detailed build that I have done.
![]() ![]() These three pictures show the modifications to the kit monocoque to fill in the control arm slots that are incorrect. ![]() ![]() I removed the molded in control boxes, and replaced them with the provided PE pieces. ![]() I attached a couple of PE pieces to the fuel rails, and built 3 of the 6 injector assemblies. ![]()
2015 Z/28 Camaro 10 Toyota Rav4 Limited (Wife drives it) 2017 Silverado |
Re: Tamiya MP 4/4 with Top Studio Super Detail
Time to get down to business. A glass of Makers Mark on the bench means it's go time.
![]() All of the injector assemblies have been built, and attached. Next will be a coat of X-18, and detail painting with X-31, and X-11.
1.5 hours on the fuel rail.
Good work so far.
Keep it up!
Slow progression...
Beautiful work! The level of detail on your model is unbelievable. Keep the updates coming please
I managed to get the axle connectors, shocks, upper control arm assembly, and some weathering on the exhaust. I also added some bolt heads from Scale Hardware to the trans-axle covers. I don't like the result on the exhaust, so I am going to redo it.
Wow, that's a lot of bits. Nice work so far. I can't wait for the return of the turbo to F1
Regards Martin |
Small update:
I got the plug wire holes drilled, and added the plug wires. I added a few cooling line connectors on the trans-axle. I added some hydraulic pieces on the back of the head covers. I added the PE pieces that go above each coil/spark plug. I will be painting these with X-18 in the morning along with XF-1 on the plug wires. ![]() ![]() ![]()
WOW!!! stunning build!!!
It's Not wheather you Win or Lose, its how you look while you play the Game |
took some time this morning to try and replicate the CF pattern of the early McLaren's. I used worn out 600 grit sandpaper to create a cross-hash pattern on the monocoque.
Great solution for the monocoque,lets see the results!!
Got some color on it this morning. You can't tell from the pictures, but the Zero Flouro Red looks blotchy. I will see what it looks like when I get home this evening. Next up, I will attempt to tackle the monocoque painting.
Well, I had to re-shoot it. I pulled out the trusty Model Master Fluorescent Red, and sprayed two coats. The paint got past the tape on 1 corner, and I need to touch up the break at the vent on the sides, but other than that, it turned out nice.
| The Following User Says Thank You to 69*Goat For This Useful Post: | ||
jonowuk (05-06-2014)
